Chevy/GMC Trucks \  tubbing s-10 for 20's
views 131
replies 8
junkman   +1y
i need to tub for 20's .there is a few ways it's done .which is the best way? it's a 1987 s-10
junkman   +1y
can anyone give me some info on doing this mod. thanks.
lowdyme   +1y
when you tub its best that you set the truck down on the rim/tire combo so you get a feel for how much your going to have to cut on the one i did it was 7 inches from the seam where the two peices of the firewall meet and that cleared the 20`s the guy had and then i cut a little bit wider on the side so you can turn a little bit while down i used a trailer fender from tractor supply but next time im just going to buy the tubs from suicide doors i think that would be a lot easy. also you have to move the wiring up that on the driver side
junkman   +1y
thanks,lowdyme for the info.trying to get this done by scrapin the coast.i am takeing two s-10's this year.
junkman   +1y
anyone else want to help out on this?
Wicked Fantacies   +1y
Yeah just put your wheels on realease the air and cut the firewall untill it lays out. Suicidedoors.com sells the tubs just trim it to fit and weld it in.
junkman   +1y
thanks nate what's the best to cut it out with? a grinder with acut off wheel on it.
lowdyme   +1y
yea you can use a grinder but a sawzall works best for some spots
junkman   +1y
thanks again lowdime.i'm going to wait and put my 20's on after scrapin the coast.i'm rollin my 18's till then.i still have to paint the other truck.
