this is the sickest vid
24 following
Fullsizerst@charter.net's avatar
FullSizeRST's avatar
FullSizeRST
titan
Add to My Profile | More Videos
FullSizeRST
go about 3/4 through the he roast the front
Dropmaster's avatar
Dropmaster
The Burnout Champion of the World.
MF
Master Fabber
Dana 60's baby!!!!! Really impressive power, sounds supercharged. Only so many burnouts can be done before it gets really old to me.
FullSizeRST
i here ya but when he melts the front tires thats what i think is sick
layedouton22z's avatar
layedouton22z
i'm just as hard on my stuff ay anyone else but this is just silly...I appreciate a good burnout but this is overkill..
slammedcavvy
ennn its cool and all but id rather see him jump it
mitsu94's avatar
mitsu94
someone has to much time and wayyyyyyyy to much money
onehightoyota's avatar
onehightoyota
its all in the gear ratio... if you've ever had a 4wd with big tires you'd know. a stock vehicle with a 3.42gear ratio and 35" tires will usually break something before it'll do a burnout but that same vehicle with a 5.29 gear ratio and those same 35's will do a powerbrake the tires idling. watch the vid close. you'll see how slow the tires are actually spinning, when he hits 3rd they aren't movin but about 30mph. in that powerbrake slide he does in 1st gear, his tires just barely are spinning, maybe not even over 5mph. all that guy has is a massive gear ratio. he has dana 60's and something like a 5.71 gear ratio. a damn souped up 4cyl could roast those tires in 1st and 2nd gear with that low of a gear ratio.
onehightoyota
half way thru the vid he does some powerslides and you can hear the truck shift from 1st into 2nd and into 3rd gear and he lets of the brake while its spinning, even though he was in 3rd gear he was still only doin about 10mph. sure its supercharged and its got big tires, but a 10year old on a 10 speed could out run that truck. that truck may have two transfer cases to lower the ratio down so far to spin the tires, needless to say, if i was at a truckshow and saw some fool doin that over and over and over, i'd kick his azz and make him quit. that whole vid ws just stupid. sure the first 3 seconds are cool, but it gets old real fast.
