how to clean overspray?
W
wannadrag03
my truck been in a shop and now has a rough over spray dust whats the best way to get that off thanks
HS
hybrid showoff
get it off what? glass? paint? laquer thinner or reducer for paint works along with some scrubbing, or very fine steel wool or razor blade. to get it off paint i would think the only way is to give it a quick wetsand and buff.
W
wannadrag03
the overspray in on the paint and the windows but the windows I can handle just was not sure about the paint..thanks
AON-JAMES's avatar
AON-JAMES
clay bar it.
W
wannadrag03
thanks for the ideas..Im try the clay bar before I go to wet sanding ....
ricky@3rdshift
I would just run a buffer over it. some finishing compound would do the trick if its just oversray that was floating in the air.
1989hb
caly bar will probably do it, if not even a heavy to mild cut would probably do it for you, i would do wet sand as a last resort just for the sake of time and amount of work.
Cracker's avatar
Cracker
I would claybar it, and then polish it with a buffing wheel. that will do the trick
W
wannadrag03
thanks for all the help ,,I will let you guys know how it goes ..I have never used a clay bar how does that work ??
Only1Platinum
I got some on one of my cars while I had the garage open and painted another car for a friend of mine. it was just clear coat over spray. a very light dusting too. just felt like the car wasn't waxed but you could see it at all. I took a mild buffing compound and buffer and with ing about 30 minutes had the car smooth again.
