Dodge Trucks \  Water Pump
Water Pump
Dodge Trucks Make Specific
views 199
replies 3
following 2
LaidNeon   +1y
Anyone replace a water pump on a 94-01 Ram 5.2l??? Mine just went out & im gonna pick up a new one tomorrow so i can tear into it tomorrow night. Just curious as to how much of a pain in the ass its going to be. My Chilton's Book says to remove the Radiator, yippie
LaidNeon   +1y
Edited: 6/7/2007 9:19:16 PM by CrucialNeon
Got off work around 6pm & got right home to start tearing into the truck. Took all of about 3 hrs, surprised the hell out of me too. Had to remove the Radiator & Shroud. Then i had to unbolt the A/C Compressor & Alternator so i could move them out of the way. Next i had to unbolt the huge bracket that held them just to finally be able to change the thermostat!!! Glad i bought one, cause i would have been pissed later on when that sucker went out & i could have changed it when i did the pump. Anyways i put in a 160 degree stat, just because i can. The old pump was shot. You could grab the front of the pulley & wiggle it around. I moved so much that the turbine inside was shaving down the metal. Not to mention the pulley on the outside started digging into the outside of the pump as well
unusualfabrication   +1y
I have the 5.9 and I just took the shroud off. Removing the fan was a pain in the ass but it went pretty good. The haynes manual says to remove it but oh well.
LaidNeon   +1y
yeah the fan was a pain the ass for me too, got the cuts & scrapes to proove it lol. The radiator came out alot easier than i expected. once you get the shroud unbolted from it, its just 2 more bolts up top & then the tranny cooler lines & of course the Coolant Hoses. Then is should just lift right out
