I have a couple questions that I need Help with. First I am building a 1986 C10 with re-7 all the way around and have the front bags on and trying to set up the rear four link now.
#1 Will the re-7 have a good ride raised 2 inches from bottomed out (front and Back)? Is it going to bottom out the bag when I hit bumps?
#2 When setting up the 4 link I plan on using 6
thacru78
You shouldn't have a problem with the ride height being 2 inches. I drove around lower than that all the time and never had problems. The slams have a built in bumpstop so they don't destroy them selves. I've rode around low enough to take out road reflectors but not lay frame without any problems. You bars should be parrallel at ride height but that's not always possible, so you can get away with them not being parrallel but it's ideal they are. Good luck with the project man, sounds like a good one.
