Isuzu \  Z71 wheel question
Z71 wheel question
Isuzu Make Specific
views 263
replies 4
tealrangerpmp   +1y
Edited: 6/7/2007 8:18:29 PM by tealrangerpmp
When i bought my truck the guy threw in a set of Z71 wheels and since im making this my daily driven bagged truck i was trying to keep this relatively low budget and was wondering if they are just a bolt on or if the hole for the hub has to bored out? trying to get some info b4 i invest in some tires. I also have a buddy with a stock set of colorado 17s, they have the same bolt pattern but i dunno if the center caps will fit anyone try them yet?
thanks Joe
mmrcustoms   +1y
go to homedepot and buy a 3 1/4 an 4 inch holesaw bits. and put the 3 1/4 in side the 4 inch and then puy it in the hub hole and cut it out that 3/4's of an inch is not bad to cut of u dont go crazy the 3 1/3 hole saw bit keeps it center
sponge splawn   +1y
If you have an 89-85 pup, and you didnt care about the look of your hubs, youcan just grind down the hub centic tabs on the front till the fit. this will also allow you to many aftermarket GM fit rims on with out much problem in the future, The back should be flat already.
tealrangerpmp   +1y
My zuu is a 91
mmrcustoms   +1y
like i said cut it with a hole saw the lil one fits in the factory chevy bore and the 4inch one is what size y need do all 4 wheels so u can swap them i am doing 07 tahoe 20's in like two days waiting to pick them up
