Toyota Trucks \  the tacoma on 20's 4" b/d
Toyota Trucks Make Specific
views 741
replies 16
following 13
gtpunk18   +1y
Who owns the tacoma on 20's with 4" body drop?? i was the profile, now i cant find it. Im trying to find out what was needed to tuck 20's in the rear. my tires rub on the inside of the body and burn the paint
DooredFord   +1y
my girlfriends 97 has 20's in back bodydropped.
Rubbed the paint cuz dumbass before us had spacers but i took those off and the bed sides are flared out a little bit doesnt rub anymore cruisin low just turns if its too low from bodyroll but not enough to burn the paint anymore.
tukked1   +1y
Originally posted by twiztedmd
Who owns the tacoma on 20you need to run a rearend out of an older yota 1985- 1993 any will work and are narrower to tuck the wheel's and the yolk is the same so no drive line repair's or changes are needed....
gtpunk18   +1y
Mines rubs and smokes off the tire when i ride low.. ive tryed flaring them.. but i have wheel tubs, i may cut them out then flare it..
if i swap a older rear end ill have to get new 4 link tabs. doesnt sound too bad..
thanx
GOT FLAKE   +1y
yeah i did the rear end swap to on that one i did it was easy takin one off and putin other one on like it was no differant it narrowed it 2 inches 1 on each side
PHATTIREGUY   +1y
you need 88-95 toyota axle 1.5 inches narrower.
timelesswhite   +1y
Rubbed the paint cuz dumbass ( Chris Kane )before us had spacers but i took those off and the bed sides are flared out a little bit doesnt rub anymore cruisin low just turns if its too low from bodyroll but not enough to burn the paint anymore.there, edited for you LoL
gtpunk18   +1y
i flared it out more and it runs hard when i lay it out.. the bed is cracked in the wheel well from the stress
granth   +1y
guy down in Laurel MS is layed on 20's all around. Stock suspension I believe. BD'd. Will be at STC i do believe
bdroppeddak   +1y
shoulda just did the rear end swap......
