71 suburban doesnt want to start
detached.org@hotmail.com's avatar
detached's avatar
detached
ok guys, so ive had the fuel pump replaced and the sending unit. im about ready to replace the fuel filter cause its the glass twist ones.
i let it sit for about a 2 week period. cause ive been busy. last time i ran it, it drove n everything just fine, well now theres no fuel in the fuel filter ive tried pumping it. using starter fluid. even threw a small amount of gas in the carb it wont run for more than a 5 second period and even then it bogs down n dies when i press the gas pedal. im pretty sure i didnt go thru 18 gallons of gas in two in town trips with less than 15 miles combined. any suggestions??
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
adjust the mixture screws it might have to high gas concentration, what kind of carb is it?
detached's avatar
detached
Edited: 6/13/2007 7:59:10 PM by DETACHED
the stock carb i think however theres no gas going thru the fuel filter.. when theres gas in the line its great runs fantastic
sic68
sounds like a bad fuel pump even though you just replaced it.
BggdNBdyDrppdJunk
are you running a mechanical or electric pump?
simple-pleasurez's avatar
simple-pleasurez
since you have one of the glass filters make sure that there isnt another fuel filter that is clogged. seen it many times
detached's avatar
detached
mechanical off the block theres so fuel filter just the glass housing still attached for fuel flow
simple-pleasurez
pull off the hose before the glass housing. get a cup and see if it will spit anything out. see if you even feel any air or anything. pull the pump off and push the lever on it you should hear air or something when you pump it. you may have a plugged fuel line
