what vaccum shit can be eliminated
slamedb22
what all can be eliminated wit a weber carb???need to kno asap thanks
BK2LIFE's avatar
BK2LIFE
everything.
but will you pass emissions? maybe not, depending on where you live
custom92's avatar
custom92
like james said you can eliminate every thing you just need the 4 basic vacum lines thats it even with the stock carb you can do that as well, you just need a breather for the valve cover i believe that it is a 5\8 one you can get them from knn, i got mine for just a hair over 30 bones so. its easy just ripp every thing out except for the fuse box and you are good to go.. good luck..
dssur's avatar
dssur
no, no you cant.
the stock carb is a feedback system that adjusts for load. If you take all the vacuum feedback off, the carb will be in "limp-home" which is default rich. Rich running washes cylinder walls and your motor will be toast in no time. These are no adjustments on the factory carb to combat this.
If you want to get rid of it, buy a weber. It is the only way to get rid of the feedback system.
low mazda's avatar
low mazda
yeah you will only need the vaccuum line from the brake booster and the one to the dizzy.
Fazethree6661's avatar
Fazethree6661
I put a weber on mine and got rid or it all but still have a cluster of wired on the side with plugs and what not.. Can anyone say what to do with all the wires and crap on the side you know what stays and what goes?
dssur's avatar
dssur
if you unplug it all, you will omly need to trim back the tape where the wiper harness is tied in and you can get rid of EVERYTHING ELSE that comes through the passenger side grommet.
Fazethree6661
so your saying I can cut everything out on the passenger side? everything but the wiper?
dssur's avatar
dssur
yes, but unplug it all first, some of it plugs into the fusebox and you dont want to short anything out. It runs along (is taped to) the motor harness too, so you will need to spit the tape to seperate the two.
