Taped DOM
cru_78@yahoo.com's avatar
Taped DOM
thacru78's avatar
thacru78
Edited: 6/29/2007 1:29:35 AM by thacru78
I'm looking for some taped DOM to use for UCA mounts similar to what is pictured below (the red arrows). I'm using a 5/8 bolt. Right now all I can find is some tube adapters but there not the right thread. I'm using a standard grade 8 bolt that is 12 tpi. Anyone know where I can find something that will work. Or a 5/8 grade 8 bolt with 18 tpi instead of the 12 tpi I have thanks for the help.
TC29720
I can probably help you out with that man, drop me a PM and i can get ya right
thacru78's avatar
thacru78
PM sent
bdroppeddak's avatar
bdroppeddak
Edited: 6/29/2007 4:17:44 AM by bdroppeddak
i can make you a piece out of solid 1018 if you want something larger than 1", or i can do it from 1" .250 wall dom, and tap it 5/8 11 or 5/8 18, but there isnt a 5/8 12.......
thacru78's avatar
thacru78
Whatever size the standard grade eight bolt from Lowe's is. I thought i measured 12 tpi, but it was probably 11. It doesn't matter how big it is. It will be wrapped in 4x2 anyways. I just don't want to have any problems with it stripping out. How much $ for 2-6 inch pieces. Also, when could you have them to me.
thacru78's avatar
thacru78
bump....
TwistedMinis's avatar
TwistedMinis
You can get 5/8 18 Grade 8 bolts. Check out Fastenal. I think you can order from them, but try to find a local supplier. Way cheaper than Lowes or ACE and way better selection. They have grade 8 from 1/4" to 1 5/8" on the shelf.
bdydrp97s10
i work at a machine shop and i could build them if you wanted me to...and i could have them done next week sometime.. drop me a pm if you want to
bdroppeddak
fastenal is a fuckin rip now that you cant get hookups if you know someone, they have a set price on everything....
TwistedMinis
Not if you know someone and they set you up an account. I got a 3/4" by 10 Grade 8 bolt for $1.35.
s10
last post by baha +1y
