dumb or tired?
dumb or tired?
ticktock200
i'm tring to do front and back on a switch box and its almost 4:30 in the morning, and ive worked 12 hours today, and i cant seem to get it to work, like wtf. its a 10 swtich box from sd.com and when i wire it up every switch clicks, i just want 2 well, id like to get 3 to work, front back and all, so what is it i'm doing wrong? going without sleep? or just tring to hard? no, dumb would prolly set this one strait ,but someone with know how point me in the right way, gut the box and only use 3 switches?
trashed's avatar
trashed
go to sleep....try it when you get up, more than likely it will work the first time you mess with it. sleep is your friend!
Fraynlame's avatar
Fraynlame
There's 9 wires in the switchbow.
1 will be 12v, 4 will be valves up, and 4 will be valves down. all the front/back/sise to side and pancake wiring is done in the box. Just make sure you got you valves wired properly and it should work no problem. And i think your just too tired 4:30 in the am, your crazy. finish it in the a.m. l8tr
s10
last post by baha +1y
