c-10 spindle
c-10 spindle
sal84
I've got a 84 chevy silverado and was wondering if I put 3inch drop spondles woild it correct my negative camber or would it drop more. front dont lay that hard. What are some ways to lay the front
bodydropped's avatar
bodydropped
to lay the frt you need drop spindles upper plates and cut the bump stop off the lca and it will lay the frt x memeber on 20s and have to trim the fenders a little also
sal84
Well it all ready lays on the x member. what would be the next step? The front wheels butter fly alot .Would i have to build my own x member out of square tubing or what?
bodydropped
depends theres a guy in az that makes a frt x memeber that lays from on a 29 inch tall tire and this is the frame under the cab it also lets you have rack steering
sal84
kool well i got stocks on it and i believe its about that same tire size. is there any way i can get a number or info on this person
TwistedMinis's avatar
TwistedMinis
You can also Z your frame, or section the stock crossmember.
bodydropped
that new x memeber does the job as them it saves you from zing it but lets you lay frame without b/d
TwistedMinis
So does sectioning the crossmember. I'm just trying to throw out some options that won't cost $2k. Rather, $0-100 ish.
WF
Wicked Fantacies
I'm telling you Z the front crossmember 2 1/2" or if u have the money comarro clip the front check finnegan's profile he has this mod done.
s10
last post by baha +1y
