forunner front end on a 86
Lotex32
do you have to use the raditor support from a forunner
ahab's avatar
ahab
I dont think you have to, i think you just have to cut for clearance
maz duh's avatar
maz duh
Are you talking a 1st generation 4runner or 2nd? If its a 1st generation clip you want to swap it should bolt right up but the 2nd gen parts will require cutting. Try and get ahold of Bob Grant for info on swapping the 2nd gen clip. I believe he has done a few and can probably give you the 411 on it.
rxtoy
i'm pretty interested in this too, like the look and i'd rather spot weld the new radiator support panel in if its got the same mounting points??????
cheers
Matt
bad andy's avatar
bad andy
You just have to cut for clearance.
