Engine swap ?
Engine swap ?
SpokaneMazda
will a 89 probe 2.2 turbo engine bolt up to my 89 mazda b2200?? If so what do i need to to do this?
reflectorcollector's avatar
reflectorcollector
it will bolt directly to your transmission...your engine brackets off the truck engine will bolt to the block of the probe motor but i believe you have to re-angle the turbo for them to fit...you will need all the wiring for that motor along with the ecm, electric fuel pump...i believe that is it
it is best if you buy the whole car
dssur's avatar
dssur
the intake faces the firewall, so does the distributor, so you will need to clearance the firewall and reverse the upper intake.
like he said, you will need the whole harness or some type of efi computer. I used MegaSquirt to convert my B2200 to EFI, it will also work great for turbo applications, and if you use the MS-II it will have spark control, you will need to add a crank trigger to the pulley.
Good luck, lots of guys want to do it but only a few ever have.
SpokaneMazda
what do you mean by reverse the upper intake?
olskoolpup
the intake is in 2 pieces, bolted together. reverse the upper half so it doesnt go over the top of the engine, but over towards the tire. ive seen a pic of someone on here that did it. cant remember who for the life of me tho.
SpokaneMazda
Thanks i will do this over the winter and have pics
madlowmazda
bongo motor
