Toyota Trucks \  relocating battery...
Toyota Trucks Make Specific
views 156
replies 4
smctoy   +1y
Ok...I know some of you guys with the 22re engine in your Toyota have relocated your battery either to the bed or somewhere on theframe. Do any of you have pics or info. on this & if any of you have pics of the whole process then why not make it a tech article?Ive seen this question asked before & Im sure Im not the only person who would like tosee it done.
fatman   +1y
im runing two kanect batt one in frunt one in the bed it is realy easy if you send me a mesag ill get back with you there is a few tricks i learned along the way and if you have an intersate batt disubter they are allways good to help
smctoy   +1y
anybody else got any info or pics??
maz duh   +1y
If you have the issue of MT with Skinned Alive on the cover there is a pic of his battery mounted down on the pass. side of the frame rail. It looks like it fits in there pretty good from what you can see in the photo. Go diggin thru your old MT mags and see if you can find it. Hope this helps
2lowtoy   +1y
You will need power wire. A: from battery to the starter pos. B: from the battery to the fuse block under the hood pos. C: from the battery to the chassis ground. D: from the body to the chassis ground. E: a battery box or a good hold down for the battery. F: good ends for the cables.
Other then that its a piece of cake.
