Nissan Trucks \  Right Hand Drive...help
Nissan Trucks Make Specific
views 393
replies 10
following 8
gettwisted07   +1y
What Do you use to convert the steering linkage? Whats the best way to convert to right hand drive?
Master Fabber   +1y
Hey, there are a few different ways to do this. 1. Get a right hand dash or fab one. Ive seen one done using a chain mechanism behind the dash to where the column mounted on the right side would turn a sprocket on the left. Kind of ghetto but would probably be the cheapest route. The other way is to source the components for your truck from a factory RHD $$$$. I also think one of the companies like flaming river or something makes a RHD mustang 2 rack that maybe could be adapted.
lx4life   +1y
I have done the conversion and you don't have to buy all that stuff. PM and I will give you a run down of what I did
BK2LIFE   +1y
the nicest way is to go on australian ebay and buy all the stuff.
for around 500 bucks you can have all the stuff delivered to yor door
onelow96cs   +1y
PM laynframe90 he did a right hand drive in his nissan.
gettwisted07   +1y
I have looked Ebay Australia but Not havin any luck finding anything.
bikerider   +1y
dose the stearing box conect to the spidels in front or behind your wheels
toddluck   +1y
sudcrap is doing it to a mazda he has a pretty good write up at mazdabscene under the project board
unusualfabrication   +1y
You can use a rack and pinion from a car that has the rack mounted behind the axle and rotate it 180 degrees. Check out my profile for the nissan.
gettwisted07   +1y
The box connects in front of the control arms and its mounted on the top of the frame rail. Can i use a rack and pinion from a Honda Prelude?
