What would happen if.......
kotalaynframe
If I put the mass airflow sensor on top of the throttle body? Because I am trying to make an engine cover with the air filter on top of the engine like a carburated engine. It's a 5.7 V8 on a Chevy Suburban. Thanx in advance
CL
Cruz Lo
I do not see a problem for the maf, but.... The IAT sensor would read hotter air than normal.
I read on other forums about relocating the IAT sensor so it is away from engine heat. So I would try moving it to say the side of the engine compartment.
Good luck.
sittinonbagz's avatar
sittinonbagz
Edited: 7/11/2007 8:08:56 PM by chevylayn22s
you dont need an engine like i said cut a whole in the floor drop the bags far enought so that you feet touch the ground them push your self with your feet thats the way i do it BAGGED 4 LIFE
dropduallie88's avatar
dropduallie88
you may be able to delete the maf altogether. check with my buddy at jimsperformance.com
kotalaynframe
if i were in shape maybe it would work im not swole like you mike
kotalaynframe
i will call jims tomarrow and see what they say thanks for the info
