Air Ride Suspensions \  best compressor?
best compressor?
Air Ride Suspensions Q & A
views 3738
replies 13
following 12
scotto79   +1y
I was wondering what would be the most reliable compressor. I want a single instead of dual, and want to know if Viair or Air Zenith has been better, and which models work best on a 7 gallon tank with both Re6s and Re8s? Thanks
delirium   +1y
If you wanna fill 7 gallons then you need more than 1 compressor. There's been a lot of down AZ compressors, just a hit and miss. Viair 480's are sweet.
loridinjamie   +1y
belt driven !!! love mine
scotto79   +1y
I have a 302 going into a Mazda, so an engine driven might be a little tight. So 2 480's will do it no problem.
balcar   +1y
Viair 480 would be the best. I have used a few AZ compressors at my shop, but I won't order them anymore, 2 many problems. Just ordered 2 480 for a customer thats ready to through his AZ out the window. Their customer support is "send it back to where you got it".
I drag   +1y
YORK 210 the only way to go
sittinonbagz   +1y
i got a viair 480 they work fuckin good
forbidden   +1y
A 480 would work great!!!!
olskoolpup   +1y
on a 7 gallon id run 2 480s or 2 450s. ive heard nothing but iffy things about the AZ, although once bugs are worked out it SHOULD be a badass comp.
an engine driven would also be dope, but finding the space might be a lil tight...
scotto79   +1y
I'm actually going with a 5 gal instead, so 1 480 would be fine, right?
