Mazda tierod ends
Mazda tierod ends
scotto79
what does everyone do with their tierods after bagging the front? I'm trying to setup the steering on mine for the first time, and there just doesn't seem to be enough angle allowed to reach between the end and the tierod. I tried to mount them on the bottom of the spindle, but there is the taper.
bdroppeddak's avatar
bdroppeddak
what size wheel and tire are you running?
scotto79
Edited: 7/15/2007 7:35:18 PM by notlowyet
225/40R18 on an 18x7.5" rim, same as stock size, maybe a half inch smaller than stock. Its a stockfloor frame, and the engine crossmember is 1/2" off the ground
bdroppeddak
my mazda had the stock frame and layed hard on my 215/35/19, which is pretty much the same size as your tires, and i know the tie rod did max out travel when it was layed out.....
maz2low
On your setup you should not have to mess with Tierods that badly . But if you want to mount them on the bottom you can take your Drivers Side TieRod Mount thats on Spindle and flip it onto the Passenger side allowing you to mount your Tierods underneath
s10
last post by baha +1y
