I'm just finishing up the stock floor on my truck finally, and was wondering how others get the tie rods hooked up with the spindles. I tried to flip the ends, but the taper won't work right, or is it needed to drill out the bottom of the spindle?
dssur
why do you need to flip them?
if thats really what you want to do, you can have the spindles machined to flip, but you will likely get bump steer.
But again, why would you need to flip them?
hollaitsjosh
I see you are running toyota spindles, are you using the toyota outer tie rod ends? because you need to.
you will need to modify your tie rods to be able to run the mazda inner tie rod end and the toyota outer tie rod end.
