Chevy/GMC Trucks \  s-10 tranny x-member
views 640
replies 10
following 7
Holeyguy66   +1y
where can i find one or who makes one
flamesaway   +1y
Why do you need a new one? Does it need to be modified? Or are you talking about a carrier bearing x-member?
Holeyguy66   +1y
i need one that is modified so i dont drag it
olskoolpup   +1y
i havent seen a s10 with a tranny xmember that hangs down. only carrier bearing x-members on like 98+ ext cabs. if thats the case, sd.com sells those.
mindlissmetalfab   +1y
No, some s10s hang down. If its just the triangle plate, remove the plate all together. Drill out the holes in the rail on the bottom to about 1/2" and use an allen head bolt inside the frame rail. If the other side is hanginf low, just cut off the bottom and re-plate it.
olskoolpup   +1y
oh shit, i know what hes taking about now.
on my s10, whoever bagged it before i got ahold of the turd basically welded on 2 plates. one to the fame and one to the xmember. drilled 2 holes for bolts and that holds everything together on that side. the other side is bolted through the side of the frame
Holeyguy66   +1y
yes tranny x-member i have a carrier bearing x-member dont need it. yes i have the plate that is below the frame. the prob is i dont want a weld on member i do have a 5 speed tranny so i wanna be able to get it all apart with out recutting to change clutchs
AVTekk   +1y
you have to cut the hump off the factory crossmember and replate it so its the same height as the frame. for the triangle, check out the mod here:
http://www.s10forum.com/trans_crossmember_plate_mod.html
Holeyguy66   +1y
thanx for the info next question what bout the exauhst it looks to low for the y pipe. or is it just a thing that comes with the territory for draggin through those on the 4.3 by the way
get an exhaust shop to build you a new y-pipe that tucks up closer. Thats about all you can do.
Thanks for posting that link Dave.. thats whet i was trying to explain. haha
