Ford Trucks \  Front brake lines....
Ford Trucks Make Specific
views 110
replies 3
ChuckDogg91   +1y
Ok so im running a different step up in the front then most of the rangers ive seen and get mad lift so much that the stock rubber brake line is not long enuff.From the brake to the first fitting mounted on the frame...Any ideas on what to use? Anyone know if a ranger 4x4 brake hose is longer?
Uncle Fester   +1y
Can have a line custom made at a shop.
mindlissmetalfab   +1y
Just bring your lines to a hydraulic shop and get them to make you some whatever length you need.
What did you do for a front set up?
ChuckDogg91   +1y
4inch bore 9 inch lift numatic cylinders...lift is pretty nasty butterflys a 20'...go's form negitive camber to postive camber in the hit of a switch....
