Question about makin center consoles
jimmyneeld@sbcglobal.net's avatar
ALL 20S's avatar
ALL 20S
I was just wonderin how some of you guys mock up your build and what materials are the best way to go. I'm wantin to start buildin one for my Luv that will hold a 8" sub then "T" in the back and hold a 6x9" behind each seat. Thanks!
low mazda's avatar
low mazda
you can use 3/8 MDF, or even some partical board. You are going to be glassing over it all right? Just kind of build the frame out of some MDF and then cover it in some fleece and continue your glassing process..
ALL 20S's avatar
ALL 20S
yeah I'm glassin over it, I was just havin some trouble of thinkin of a way for mock up. Thanks
phillip's avatar
phillip
cut some rings for your speakers and some strips of wood us the sticks of wood to suspend the rings where you want them then pull fleece over them tight staple on backside and resin
unfadeble's avatar
unfadeble
this guys got his own section on this forum. Hes got lots n lots of pics and some good tips and tricks. heres one of his current builds http://www.stevemeadedesigns.com/board/index.php?showtopic=7523
