Squeak!
mavverik@sbcglobal.net's avatar
Squeak!
TwistedMinis's avatar
TwistedMinis
Okay so driving my truck around, I occasionally get a sharp squeak, that I think is coming from the front suspension. Really only happens when I'm driving with the front down 2-3" off the ground. 4" and above I don't get it. Sometimes it happens when I hit a bump, never on big bumps. But sometimes it just happens at random on a smooth road. Its really fucking annoying. I tightened everything up real snug but my lower arms this morning. Is it maybe just the poly bushings in the arms?
simple-pleasurez's avatar
simple-pleasurez
check all your bushings. sway bar if you have one. check your johnson rod.
TwistedMinis
Only bushings are in the lower arm, but I will check them tonight. They might just need some lube.
LOWEST1's avatar
LOWEST1
Poly skeaks if you dont lube it good.
TwistedMinis
Is there something specific that works well? I know poly swells in reaction to some chemicals.
sittinonbagz's avatar
sittinonbagz
just lube it
s10
last post by baha +1y
