Body work and Paint \  another body work q..
Body work and Paint Q & A
views 143
replies 4
following 5
yasmany454ss   +1y
ok lets say i have a ding or a spot that i shaved..well i take it to bare metal and feather out the old paint then i put filler over the bare metal.. but when i sand im going to have a few spots were the filler did not cover or whent away when i sanded that exposes bare metal..what i do i put some selfetching primer over those spots or the filler primer by it self.also wont bare metal rust under the body filler
bodydropped85   +1y
i use a DTM urethane hi build primer. no need for that. as long as you dont use spray can youll be fine.
Small Froddy   +1y
as long as bare metal is covered with anything it won't rust... i've never had problems with rust coming through and i've never used selfetching primer
Wicked Fantacies   +1y
Body filler is made to adhere to metal. After that u can use a high build primer and I've seen people use a good sealer primer to lock in the body work once its finished.
wymplo94   +1y
etching primer isnt really for rust epoxy primer is etch is so your surfacer can stick primer doesnt have good adehsion to bare metal unless it has a acid base.
