Mazda Trucks \  Will 4.5" Backspacing on an 7" wheel tuck
Mazda Trucks Make Specific
views 147
replies 5
following 5
idragmazda   +1y
Edited: 7/31/2007 10:58:44 AM by idragmazda
I know this wheel stuff has been beaten over and over, but I just want to double check before I spend some money on some wheels.
Will 18"x7" wheels with 4.5" backspacing tuck on a Bodydropped mazda w/ 4wd fenders and drop spindles (i know the drop spindles add an inch, but i'm shimming the upper control arm in a little bit for some negative camber). Any help is greatly appreciated, thanks guys.
mazberrydelight   +1y
on a 7" wide wheel you need a minimun of 5.5" backspacing otherwise you'll rub the bedsides up by the upper bodyline . order a 5.625 or 5.75 backspacing if you can
dssur   +1y
no, not even a little chance. 4.5 backspace on an 7 inch wheel is +13 offset, thats about a third of what you need with drop spindles on a 7.
And FYI a 4x4 bed only helps if you arent bodydropped, otherwise the upper taper of the bedside will hit the tire.
idragmazda   +1y
well the rear end is getting narrowed. but for the front, what size offset and backspacing can i run to achive the biggest lip? Thanks.
scotto79   +1y
right now I'm setting up an 18x7.5 rim with a 40 series tire, and I'm running a +45 offset with the 5 bolt swap on CanDo arms so the dimensions are the same as stock.
slammedstroller   +1y
I was running 18x7.5 with a 38mm offset and clearing fine in the front
