tow hitch setups
tow hitch setups
bdcrewdually
i was just wondering why in all these magazines i see that all the hitch setup's are all bolted in between the frame rails over the axle?is there a reason that they r bolted in instead of being welded in which would seem stronger? was always wondering any help thanks
W
watahyahknow
it might be the fact that you need lesser tools to bolt in a factorie made hitch .
in most cars the boltholes are allready in the chassis , bolts are simple to use even for a unskilled person they cant garantee someones weldingskills to be sufficient
low95xlt
Wat i think he sayin there are several that have fancy tube work and they are attached to the frame notchs via bolts... i think some of it is looks and where the ball is thats all welded but i could be wrong
got6wls's avatar
got6wls
When you have you're articualated Notch/Hitch nount setups, you can build/bend, paint then install, it takes too much time tape off the hitch tubing to paint something in a flashy color for this setup when wedled, though it is done by many and it looks impressive when welded. Plus when you build then bolt in with some 'CHROME' bolts it looks great too. Also if you want to take the hitch off and replace with notch cover you would not have any protrutions, just a nice notch cover/tunnel. Plus when you have a ball/reciever mounted on the center of your hitch it gives it that 'Hauler' look which is what these truck were originally designed to do. It's all preference!!!
loweredd
That is the weight rating of the hitch. What will you be towing?
