Lower Link Bars
texmextukin@yahoo.com's avatar
Lower Link Bars
Texmextukin's avatar
Texmextukin
Is it true that if i run my link bars from my front hangers on my S-10 that they will hit the frame before i lay? If its any use, im using 2x2,the axle tabs are from Suicide(I dont remember how far they hang down)and Im laying 20's. Thanks for any help guys
mindlissmetalfab's avatar
mindlissmetalfab
They will hit the top of the spring hanger. You just have to notch it out. I've never heard of them hitting the frame.
olskoolpup
joel's right. however, the leaf spring hangers will lay before the frame does, and if you drag, it will drag through the bushing. you can cut the rivets off and move the hangers back a little bit and you'll be fine. the bars will be shorter, but as long as you det up the links right, youll have no probs.
good luck!
Texmextukin
I really dont plan on Draggin, just sittin low. I just wanted to be sure about this be cause I read on here that some dude said they would hit the frame. Thanks guys
s10
last post by baha +1y
