Does anybody have or know where i can find smooth bed caps for a 2001 ford f150 supercrew?
DooredFord
sporttruckdirect.com
stylinconcepts.com
If you're talking about the street scene urethane ones.
jmn444
street scene makes em part #'s 70725 & 70726
type in those part numbers on summit and you can get em there... prob lots of other places too.
jmn444
don't expect perfection though, they are a bit wavy, but fixable. i mounted them, then blocked em, then primed and re-blocked, still a bit wavy, but good enuff. should use flexible primer for it too... which blocks for shit...
lowfrontier03
yea street scene sells them they are deffentley wavy but i must may look way better then stock once installed
22dragn
or just take your's off and smooth them your self just be careful not to burn through them, then just use body filler and smooth back out and prep and paint
jmn444
that'd be tough to get the factory ones (if they are similar to ext cab version) to fit like the street scene ones do, you'd have to add a lot of material along the bottoms to get them to meet up to that body line flush. not even sure it'd be possible to do it in a way that'd last without cracking.
if money isn't much of an object, I know that grant kustoms will make metal ones for you, but i can't remember what they quoted me for it...
