Full Size Truckin General \  bagging a c1500 reg cab pick up (90model)
views 387
replies 4
ryan3500   +1y
as the title says i want to bag my truck 90 model swb c1500. im from australia and there is not a great deal of info on them over here. iam just wondering if anyone has some pictures of there set ups for front and rear. i will be running a tri angular 4 link also. just need pics of bag positions and also the notch set up as these are just the c section chassis if that makes sense. it has to lay 22's also so any ideas please and rim offset would be good. thanks ryan
SHOWTIME   +1y
do you have the triangular 4 link alreaby?if not look at kp komponents 6 link it's a parallel 4 link with 2 bars that go back to the rear of the frame they get great lift and are super easy to install and they ride awsome i have had mine in for 2 years now never had a problem
dreamworxinc   +1y
4 link with a watts link is the only way to go. i've been there and done that. if you can found some one down there that can install a setup for you. you can get the parts. good luck
ryan3500   +1y
yeah i have seen them a guy over here has got one of them kits in his x-cab but im pretty sure the engineer will say no to a bolt in type kit in the state i live in as there modifying rules are very strict.
ryan3500   +1y
has anyone got any rear end setups and how do you go with the notch as its a c channel chassis
