daveg
on the cross member closest to the cab, grind or drill out the hot rivets make some spacers 3/4-1" long (need 4)and bolt the cross member back to the frame with the spacers in between the frame and the member.
the rear member is a little more involved, but still easy. drop the tank, and cut the member off as close to the frame as u can, i usually use a sawzall. weld a piece of angle to the frame on both sides for the member to sit on and then weld the member to the angle. i think i usually raise the rear member 2-2 1/4". have some pics if u need them just send me ur email and i will send them to u....
