How do you bag the front of the taco?
Deadman_Drag
How do you bag the front of the taco? anyone have pics?
acromexicant's avatar
acromexicant
i dont have pics but im doin mine like any torsion bar setup, just cut the spring tower out ,and use suicide doors or any import truck bracket
TwistedPhil's avatar
TwistedPhil
It depends on what size wheel you want to run, and if you're planning to flip the lower balljoints.
We have a bracket that installs into the factory spring pocket and bolts to the lower control arm, which makes for an easy installation. However, if you're dropping on 18s and up, these brackets end up needing to be modified quite a bit to lay frame. If you combine them with a spacer on the lower balljoint, then you can get on the ground with the larger wheel/ tire combos.
There's nothing wrong with cutting everything out and putting an import bracket in place of the spring pocket, but it's a lot of work that you may not need to do!
-Phil at FBI
DDlowztaco's avatar
DDlowztaco
I have a picture on my profile on how I did mine
Deadman_Drag
Do you have pics of how you bagged the front, i did my s-10 but i used cups. i dont know how to do the front. the back is cake
DDlowztaco's avatar
DDlowztaco
I uploaded a pic on there now
