?????? ABOUT TUBING WITH DIMPLE/ HOLES IN IT.
thebrantleys3@gmail.com's avatar
LndRanger86's avatar
LndRanger86
I WAS WONDERING HOW PEOPLE MAKE THE TUBING THAT HAS HOLES DRILLED THROUGH IT TO THE OTHER SIDE AND THEY ARE IN A DIMPLE TYPE INDENTION.HOW DO THEY MAKE THOSE INDENTIONS. I COULDN'T FIND A PIC AS A REFERENCE BUT I'VE SEEN THEM ON ALOT OF MOTORCYCLE FORKS TO. THANKS FOR ANY INPUT.
Boozehound's avatar
Boozehound
Search for dimple dies
jeebus @ mmw's avatar
jeebus @ mmw
ive done it in the past on a mill.
sometimes run an end mill, perpendicular into it, sometimes they drill a hole strait through, it depends on what style your looking for.
Ive heard it called alot of things, i allways call it machine gun style, just because alot of older machine guns have barrel shrouds that are done that way, to protect your hands from the hot barrel.
ive never heard of it done with a dimple die, and im not sure that its possible or desireable that way.
Low_SST's avatar
Low_SST
you couldnt dimple on a radius like that drilling through can be done easy tho
the new issue of minitrucking has the website in the top tools article
bdroppeddak's avatar
bdroppeddak
you cant dimple a piece of tubing since you cant get the die inside of it... like taylor said, you can do it on a mill pretty much drilling and radiusing the edge of the hole....
LndRanger86
THANKS GUYS. THAT HELPS ALOT.
tooleyhc's avatar
tooleyhc
I've seen people drill holes in the tubing and insert a piece of tubing the same size as the hole and weld it in.
The dimple dies refered to earlier are used in flat piesed, cuz the die itself is 2 pieces. There's no way to get the second piece in the tube.
LndRanger86
THANKS
LndRanger86
ANY PICTURES? ANYBODY DONE THAT TO YOUR RIDES?
s10
last post by baha +1y
