ever had this happen.... what will fix it...
2be1off
i have a 86 toyota excab pickup 22re. what would cause my idle to fluckurate from 1500 to 2100 rpms at an idle? do you of you know how to fix it. its bugging the piss out of me. need help asap. suggestions would help thanks.
dragamazdog's avatar
dragamazdog
its either your idle speed sensor or throttle position sensor most of the time when that happens either one of those went bad
2be1off
thanks i replace my throttle pos sensor already i`ll try the other thanks
2be1off
any others???
corey0814's avatar
corey0814
spray carb cleaner around the throttle body & all over any vacuum lines. i'd check for vacuum leaks before i spend the money on an IAC valve.
2be1off
were in the f is the idle speed sensor located. i know its a pretty dumb ? to ask but any help it would be great. some one is comin to look at it today to buy i hope
truck action's avatar
truck action
Edited: 8/12/2007 11:01:25 AM by truck action
Had this happen on my brand new LC engine, it was a bad thermostat. There is a duel type one from the dealer that will work much better. I used it and problem solved. The engine won't come out of cold start mode,it will kill the cat also!!
Severed701's avatar
Severed701
check your coolant level...
low downin's avatar
low downin
coolant problem caused mine in both my 86 and my 94
