tacoma rotors ona 84-95?
jpacker72@gmail.com's avatar
FluffyFreak's avatar
FluffyFreak
is it possible? what would i need to swap in the front to do this? i knwo the rear all id need is the rearend duh!
TwistedMinis's avatar
TwistedMinis
Just remember the Taco axle is wider.
FluffyFreak
so narrowering the the axle would be in order....ok but what about the front? is it as simple as swappin spindles? or would i need to look into taco C-arms?
sadisticiron's avatar
sadisticiron
rotors will fit the older spindle but it has a slight diff. offset and a little bit bigger
sadisticiron
why would you want to change anyways
FluffyFreak
bigger rim selection
sadisticiron
its the same lug pattern
FluffyFreak
yeah but the hub bore is different....and theres not really any shops around here to get hubs milled out
sadisticiron
any machine shop can do it and you can use a brake lathe to mill the hubs down too
TwistedMinis
Yea pretty much any machine shop with bore hubs out. Just don't go to an engine machine shop, they wont do it. The place I went to said they normally don't do automotive stuff, but did it under the table. They did a nice job too.
And on the rear axle, the bore size doesn't really matter. I had all 4 of my wheels bored to fit the front, and they are way bigger than they need to be to fit the rear axle.
