How short is your distance, and how long is a while?
Without your o2 sensor your truck will run in "closed loop" mode, where it will provide fuel based on the reading from the mass airflow sensor, but won't have anything to verify your a/f ratio by- this is what your o2 sensor is there for.
It will run, but if your ecu is pumping out more fuel than it should, you could ruin your catalytic converter (if you still have one), and run the risk of damage to the engine internals over a long period.
But short local trips for a week or so should be cool. Good luck!
-Phil at FBI
