Relocating stock fuel tank ?'s
9
90isuzupup
I have a question for you guys. How hard is it to mount the stock fuel tank behind the axle?
I want to keep my stock tank without running a reversed 4-link.
Thanks
keele's avatar
keele
Not hard just have to exstend the wires and fuel lines and make a mount behind the axle. Mine was real easy
9
90isuzupup
Thanks
mmrcustoms's avatar
mmrcustoms
ine is in the bed untail i get off my lazy ass and put my fuel cell i bought in
9
90isuzupup
I hear ya, where and how much did you get your grill from? Nice truck BTW
domepiece
It's pretty easy. I cut a little out of my inner frame to insert a new crossmember. Once the new crossmember is in you can cut out the old spare tire crossmember. Then a couple pieces of angle iron welded to the new crossmember at the right angle, extend the wires and lines, and cut the bed. I always set them up with the front tires a couple inches off the ground and the rear end down and a 2x4 under the tank. This just ensures you'll never drag it. It's also not a bad idea to add some braces to the angle at the end by the axle. Here's a pic.
aaskelvis's avatar
aaskelvis
IF YOU NEED A RODEO GRILL I THINK I HAVE AN EXTRA ONE
jucieddawg's avatar
jucieddawg
I just bought a fuel cell, I got an nice polished one for $140. Tkaes care of trying to mouhg the big bulky stock one..
jestermetalwerx
go to a junk yard and get a rodeo tank will fit under the stock bed and you can use the sending unit
Related Discussions in Isuzu
