whytry85
BioMax
View other posts by this member. Posted - 7 January 2007 10:26
Originally posted by bagged2200
bio See I have a 89 silverado and i got i to the frame stockflooring it and im to the point where im build building my 4 link and i tought i knew how to set the 4 link up but know im reading all this i want it to be right ( i put 4 links on before but i always welded axle to frame before i took the leaf spings off then installed links then cut the axle loose im guess thats the wrong way ?) I understand the degrees on the drive shaft at ride height , but what about the about the bars should they be at a certain degree at ride height thats where im lost thanks
I try to keep things close to parallel to the ground at half travel. I posted once in a different thread about the bars being parallel to the ground at ride height, but in sticking to an i.c. not all of the bars can be parallel to the ground. As long as the i.c. is somewhere out towards the grille and the bars are parallel(ish) to the ground at ride height, the system should work really well. If you are forced to use short bars you will need to do a little more figuring, but just to stay safe.
