Air Ride Suspensions \  slipjoint 3 link?
slipjoint 3 link?
Air Ride Suspensions Q & A
views 282
replies 13
following 11
granth   +1y
I was watching muscle car TV this morning and they put a 3 link over their little fox body mustang, but it was different. The single end actually would slide in/out of the "wishbone" part. Seems like it could help with the long travel that some of the minis are getting? Would it help pinion angle and all any?
ben_shady1   +1y
That's what I'm putting on my dually... but it's more of a track locater. It's just to keep my rearend centered... We are using it with a parallel 4 link. Works better than a panhard and in my eyes is stronger than a watts link. I dunno how good it would work with a 2 link.. It wouldn't have anything to do with pinion angle..
BioMax   +1y
I've seen a lot of those tricky parts and pieces that make things look neat, but there is no reason to use something like that on a mini. They are mostly designed to aid with traction and are not at all needed for a mini.
baggedwagon69   +1y
my car is set up with the same link works great only thang is i have to lube the shaft every once in a blue moon.but will let it get a lot of lift
Deuce   +1y
i built a wishbone for my truck but i made all my pivot points in line... all the pivots pivot together, no need for a slider. i was going to do my wishbone with a slide until i built the plate that sandwiches between the T/A rearend cover and the rear end. check out my profile and you can see how i did this.
K.I.S.S. - Keep It Simple Stupid...
BioMax   +1y
Tony- That looks good. Nicely done.
I'm not saying that you can't use something like that, but there is plenty of room under the bed of a mini to build a system that doesn't need anything fancy. You could easily get 24" of travel out of a simple 4-link with zero issues, it just needs to addressed properly.
MagicMikey   +1y
i agree i did a ranger that i tested 21 inches with a normal 4 link that, it didnt go out of wack any were, it would have gone more if i had a taller jack and a longer break line lol.
Does anyone have a pic of the slipjoint 3 link? i havent seen one.
granth   +1y
why not use just a panhard bar rather than a wishbone? I like the setup, but how does it work with the pivot for the wishbone below the axle?
ben_shady1   +1y
we aren't gonna use a panhard because it's a dually and there's no room for it to move side to side back there. SO it's gonna be a parallel 4 link with a wishbone for keeping the rearend centered thru the range of motion. On my mazda I had a 2 link with a cross bar.. a link from the front of one bar to the rear of the other. had a bushing on each end so it had a bit of articulation. Silverstar uses a cross bar that's just a piece of flat plate welded inbetween the 2 bars behind the rearend. I've never seen anyone have any luck with this. I've seen several cross links like I had one several trucks and have never seen a problem. It keeps the rear from having any movement from side to side.
BioMax   +1y
A fully parallel 4-link has no roll-center, so the wishbone only acts as a lateral limiter and gives the system a roll-center. That's it.
