Mazda Trucks \  couple questions
couple questions
Mazda Trucks Make Specific
views 320
replies 10
following 6
mazdarado   +1y
I've got Cando arms. Has anybody had any problems with Aim toyota drop spindles? Who's got the cheapest Belltech?
What kind of brake booster is everyone using with 20's?
Also where's the cheapest place to get clear corners? Right now ebay is the only place I can find and they're $57 dollars. Thanks
scotto79   +1y
did you get the Cando mazda/mazda arms instead of the ones that bolt straight to the toyota spindles?
mazdarado   +1y
no I got the mazda2yota arms.
maddawg   +1y
i did'nt have any problems with the stock booster, buti am currently useing a 7" dual diaphram for braking reasons.
mazdarado   +1y
Great. Thanks for the replies. BTW Rudy your truck is badass.
scotto79   +1y
Then the AIM spindles are most likely your problem. The taper is off a little bit probably.
mazdarado   +1y
No, I don't have them yet. I was just wondering if Aim's spindles are alright or if I should just spend the extra money and buy Belltech.
Who's got cheap clear corners?
50s dragger   +1y
EVERY THING AIM SELLS IS OFF A LITTLE BIT!!
dssur   +1y
no, everything about them sucks. They push the wheel out about an inch, you have to run at least a 16" wheel, the spindle nut likes to crossthread, and the lower balljoint hardware is a fricking joke. I had to redrill all eight holes in the balljoint plate for my Mazda drop spindles because every single one was crooked.
Belltech is much better stuff for Toyota drop spindles.
ebay only, thats the only place I have seen them in a loooong time.
mazdarado   +1y
Thanks Russ. I knew the aim mazda drop spindles push the wheel out but I hadn't heard anything about their yota spindles.
That sucks about clear corners. I hate to give 57 bucks for them. Only one person is selling them on there.
