is it just a light coat of paint and then cleared?
dragggn
scuff light with 600
rub out any casting marks,
and D.O.T. raised lettering
over reduce the basecoat(by 2x,
then clear as usuall --cut, buff,,
SF
Small Froddy
i mixed black in the clear on mine, then just do as many layers to get em as dark as you want
impulse
sounds like either way works?
gravity5
Use black kandy toner in intercoat clear.... scuff up with 800 then do as many light even coats as you like to achieve the shade you want. Then clear with a proper 2k catalyzed clear. Using basecoat, even overreduced base will reduce the light output greatly for the same shade as the kandy toned clear basecoat.
SF
Small Froddy
i only put a few drops of paint in the clear, so it's bout the same as candy, but any of these ways will work it sounds like to me, also make sure you use adhesion promoter first
