98 S-10 clutch master cylinder relocation
chris@unusualfabrication.com's avatar
unusualfabrication's avatar
unusualfabrication
For those that have an S-10 with a 2.2lt 5 speed, bodied, on 20's, what did you do with the clutch master cylinder? I know that I can probably move it to the inside of the cab. Just looking for some options and maybe some pics. The push rod is this fancy looking plastic thing, not a metal one like they used to be. The tire rubbed a hole in the resevoir (sp).
jumbo's avatar
jumbo
we moved mine up 3" and over 1 1/2". You have to make a new linkage to go from the clutch pedal to the cylinder, and have to notch out the big ass metal bracket behind the dash (the one the clutch and brake pedals are attached to).
unusualfabrication
was yours that fancy plastic linkage?
jumbo's avatar
jumbo
yup, mine's a 99. My buddy started taking all that plastic shit apart and i was freaking out, but he figured it out. He ended up making a bracket that moved the slave cylinder over, and used all thread to make the connection from the pedal to the cylinder, this way i have adjustability.
AVTekk's avatar
AVTekk
ya you just need to recess it into the firewall a little bit and move it up. lots of pics on s10forum.com. in the bagginit section.
