Page 1 of 3
Air Ride Suspensions \  Need help installing FBI digital gauges?
Air Ride Suspensions Q & A
views 827
replies 21
following 10
belowclvl   +1y
It came with the instructions but they arent very clear. Where do you hook the sending units up at? If anyone knows a website that has a diagram drawn out or something that would great thanks.
belowclvl   +1y
thanks for all the help!!!!!
TwistedPhil   +1y
Didn't see this post until just now!!
http://www.fbirides.com/assets/files/install_files/260215.pdf
That's the newer instructions- I think they should answer most of your questions.The sending units install between the lift valve and the airbag at each corner- of course, the tank sender installs in the tank!We have T fittings for your valves that have an 1/8" port machined into them for the sending unit, or you can just T into the line from the valves to the bags for the sender.
Let me know if you have any other questions!
-Phil at FBI
FullSizeRST   +1y
this is how i did the rear with dakota digi. gages its all most the same set up, but i whent with the 400 psi sending units wich require a ground
FullSizeRST   +1y
hope that helps man
belowclvl   +1y
do i need to buy a certain fitting to get the sending unit into the t valve?
belowclvl   +1y
hey thanks alot bro for all the help?
belowclvl   +1y
belowclvl   +1y
I have the smc valves do you have the fitting for those?
