bagging 2000 neon
dragit@netscape.com's avatar
bagging 2000 neon
dragit89sdime's avatar
dragit89sdime
Edited: 8/27/2007 7:14:01 PM by dragit89sdime
quick question i got a 2000 dodge neon and a buddy of mine has a set of struts and a set of cylinders off a 97ish honda. My question is will those work on the neon. ive never put air on a car just minitrucks so im new to this type of setup. any help would be appreciated.
Myspace Graphics
twistedsdime's avatar
twistedsdime
You def. need to talk to Dan. His name on here is Crucial Neon. His set up is badass but its on bags. But he can def help you out with your air setup.
LaidNeon's avatar
LaidNeon
Our cars have McPherson struts in the front, which means the strut turns as the wheel is turned
Most honda's have upper control arms, so their struts don't move except up & down
I have seen a few Mac Strut designed cars on cylinders, so it can be done. You just have to make custom brackets obviously. I know in my original design to get my front end lower i was going to use Cylinders................because of how far up my rim/tire go into the fender well, i couldn't get the cylinder to clear it. Obviously i scraped that idea. If i were you, i would go with a strut bag setup
http://www.easystreetair.com/index.asp?PageAction=VIEWCATS&Category=119
If you are curious, 1st gen neon suspension parts will work for the 2nd gen
dragit89sdime
hey dan thanks for the info its much appreciated.
LaidNeon's avatar
LaidNeon
not a problem, if you have anymore questions bro just hit me up
