stuck valves
stuck valves
tsm27
when i try and air up the back of my truck the valve is staying open so the bags cannot inflate. does anyone have a fix for this problem other then replacing the valve.
kevin@aac
open it up and see what is stuck in there. Clean the diaphram with some air tool oil. and reassemble.
fatman's avatar
fatman
did you just put them in or have they been in for awill
tsm27
been in for a while. started as a slow leak but know they just stay open.
fatman's avatar
fatman
what kind are they but you should be able to take apart and cleen them
kevin@aac
open them up, time to learn.
ND
NC Dave
sounds like they just need to be oiled just do as the cat above said just open them up spray in some oil or w/d 40
nryota's avatar
nryota
test it before you open it hit it with some wd before you even take them outta the truck, just spray in the valve and hit the switch a few times maybe even tap them with a hammer(lightly) and see if you can free them.
s10
last post by baha +1y
