xm radio on pioneer
xm radio on pioneer
bluedime
was just wondering is it hard to hook up xm radio on a pioneer cd player and where is the best place to run the antenna,its a 98 accord
90maz's avatar
90maz
It's easy to hook up it should all just plug in. I put the antennas on the passenger side dash in the corner and mount them with dubble sided tape.
Twisted Galant's avatar
Twisted Galant
They are easy to hook up. There are a couple different systems ypu can do. One would be the pioneer direct connect xm Tuner . Two would be the Terk XM tuner and get the Pioneer xm tuner adaptor, Which is what I have in my Jeep. The only downfall With the Terk unit is it doesnt have anymore IP bus Extensions to hook up other things such as a changer, bluetooth adaptor etc. Although most of the "PIONEER" IP bus adaptors usually have an extensionThat you could hook the XM up to. Its merely a choice factor. The Terk system with the adaptor, tuner and antenna run around $100-$120. The Pioneer brand runs around $100.00
Twisted Galant
Oh yeah as far as antenna. I would recommend putting it on the outside of the car. 9 times out of 10 it will work on the dash but it will cut in and out more. I usually mount the antenna next to the windshield seal on the roof and center it up with the rear view mirror. Run the wire down the window seal and run it through the door jamb boot and run it to where you will put the tuner
