1999 ford ranger camber
laidout83ranger
i just wanted to know what i can can do to reduce the camber. its bagged on 17s. i just bought it and i was told if i put cups on the bottom that would help. and it still as the factory upper control arms. any suggestions would be great thanks.
lobdyblazr
Have you taken it to a reputable alignment shop? There an off-set control arm bolt kit for those trucks. It will push the uppers out alot further than the factory bolts do. Shop here in town has em..he charges less for the alignment if I get them and stick em in while bagging the truck.
draggin04's avatar
draggin04
you can move the upper arm up a couple of inchs and that will fix it
greenranger 23's avatar
greenranger 23
i added 1 5/8 inch to mine
laidout83ranger
its aligned but dont know what shop done it. you add the 1 5/8 inches to the factory upper arm?
draggin04's avatar
draggin04
yeah its a easy thing to do i just said the hell with and runnin with the camber just maker sure there the same on both sides
laidout83ranger
thanks for the help
