Air Ride Suspensions \  How low can I go?
How low can I go?
Air Ride Suspensions Q & A
views 288
replies 14
following 8
BIGBODYBUICK   +1y
I have a 95 dime that I want to static drop for the time being, how low can I go and not have issues with alighnment and scraping on everything? I was thinking 5" front and rear too much?
granth   +1y
Edited: 9/3/2007 6:24:32 PM by 72bumpside
depends how fat you are.
BIGBODYBUICK   +1y
I'm a BIG guy, almost went with a fullsize to haul my ass
draggin04   +1y
depends on the wheel size to
xflowgolf   +1y
what size wheels/tires are you running?
BIGBODYBUICK   +1y
I think i'm going to run 15x7 smoothies with wide whites I plan on using it for a daily for a while Looking something clean and ol skool Tire size? probably something close to stock
BIGBODYBUICK   +1y
I need to know how far to drop it can someone give me some advice?
TwistedPhil   +1y
Depends on standard or extra cab, too, but in my opinion anything bigger than 3/4 is going to make you miserable.
Spindles and coils up front for a 3 or 4" drop, and blocks in the rear to level it out. Don't spend big money on the static drop since you'll only re-use the spindles once you bag it...
Figure on around $300 retail for those items, plus around 50-75 to align it when you're done.
Good luck!
-Phil at FBI
BIGBODYBUICK   +1y
It's a reg cab and a longbed Does that make much of a differnce?
draggin04   +1y
if the smoothness of the ride dont matter then do the 5/6 if it does then a 3/4 would be perfect it would still sit low cause of the wheel and tire combo
