Air Ride Suspensions \  replacing a valve
replacing a valve
Air Ride Suspensions Q & A
views 159
replies 1
following 2
tsm27   +1y
i am replacing a valve on my truck because it is stuck in the open position. Since when i air up the rear drivers side bag and the valve stays open i only need to get one valve correct?
TwistedPhil   +1y
Before you go tearing down your entire setup, have you checked to see what's holding it open?
Disconnect the wiring to see if it's still stuck open- if it closes, then you have a wiring issue.
You may also just have some crud stuck in the valve that's holding it open- in that case, you can disassemble most valves without taking them off the truck so you can clean it...
Just trying to save you time and money- I hate taking valves out of a system!
But yes, if that valve is completely toast, and it's just the lift or dump valve, that would just be one valve to replace. Good luck!
-Phil at FBI
