Ford Trucks \  starting after sitting for several hours
Ford Trucks Make Specific
views 141
replies 3
phillip   +1y
someone on here has to have had this problem before, turn on switch no pump, new fuel pump, new filter, after turning switch on and off or sometimes just leaving it on for like a min or 2 then off then back on the pump cuts on changed relays and everything make no since to me help is appriciated oh and it is a 95 3.0 thanks guys
exotic dreams   +1y
Check the inertia switch under the passenger side dash on the firewall. Also the clutch safety switch could be making a bad connection when depressed, just take it apart and clean it a little. Check the power from the distribution box to the inertia swith, then to the pink/black wire to the pump (the furthest wire to the left of the connector). Also what else is not working?
bodydropped85   +1y
if its an auto, try puttin it in neutral.
phillip   +1y
do you know what the third wire is its a small wire
